A 120mm in lower front, another for a blowhole, and you should be good to go, especially with watercooling. Remember, your PSU fan is also exhausting heat. If you are attaching your radiator to the case, however, you might want to use 1 or 2 fans blowing out the back, and eliminate the blowhole.
