Desired temp for idle CPU is between 28-35 degrees Celcius, with a max temp for full CPU usage between 40-50 degrees Celcius. Of course this depends on how much you stress your system, and how well the case is ventilated. The cooler you keep your case will assist your CPU cooling, as it will also return to idle temps quicker.
