What is sidebanding?
Mictlan
Senior OC BOINC User
Mexico City, Mexico
I was checking in Sandra the AGP specs and it said that the card was capable of sidebanding, but it was disable. What is this good for? How do I enable it?
Well if you check out the tips section under video cards it will tell you :) I'm not sure how to explain it or i would tell you but i know this for overclocking you want your sidebanding disabled this will allow higher FSB settings I could not get over 1200 with enabled sideband but disabled i was up to 1248 on a 1gp3 if youirs is disabled your set just rite :)
