Badger (Jun 16, 2001 01:40 a.m.):
Taylor (Jun 16, 2001 01:28 a.m.):
how about with another pelt?
(just kidding)
So do I have this straight? that cold side only stays cold as long as the heat comes off the hot side at least as fast as it leaves the cold side?
This makes me wonder why to use a pelt, if I have it right. You need to remove the same amount of heat, why bother putting it through a peltier before removing it?
So where am I wrong here? I know I must be because you guys wouldn't be wasting your time if this were the case.
With a pelt you actually need to remove more heat, MUCH MORE !.
For a cpu giving off 80W of heat the total heat load with a suitably rated pelt would be over 300W, so you need a really good cooling system to cool a pelt.
The advantage is the pelt generates a Delta T, that is the cold side is up to 70C cooler than the hot side, so providing the hot side is cooled you can chill your cpu to below ambient or even below freezing temps.
Straight air or water coolers no matter how efficient can never cool below ambient.
