What is the correct placement for case fans?
killem2
In another thread I will be building a wooden case. However, I need to know what ways the fans really should be pointing and how many.
The easy part is the two 120mm in the back point out and the two 120mm fans point in from the front.
However I was thinking of some fans on the top as well. Should I have 1? 2? pushing air in? pulling air out?
One big fan? like a 250m fan?
baditude_df
Northern Senior
Rear and top fans are exhaust fans. Front fans are intakes. It's as easy as that.
You can have all the unrestricted airflow and cold air intakes as you want, but without the capacity to remove the resultant warm air, you're screwed.
Moto7451
Senior Something
LA, CA
You don't really need to push the air up since we're forcing the air to do what we want. Convection is more important with passive cooling setups.
I tend to buy/make computer cases with one or two rear 120mm exhaust fans and at least one 120 in the front. You can run more intake than exhaust and it'll keep the dust down but I tend to like running a negative delta air pressure and deal with dusting things off a little more.
bing
Low Profile Senior
Indonesia
Since you will be making the case yourself, consider 140 mm for case fans rather than 120 mm, they will move more air with less noise (if this is really matter).
ehume
I saw a Silverstone vid where they used the top fans as intakes. And then I saw a review where the reviewer was in some consternation because the Silverstone cases overall cooled well.
I know this subject is reasonably well known. Thoughts?
I'm not trolling. I'm working on an NZXT Beta Evo, and I have some great Scythe Kaze Maru fans that work far, far better when they are pushing down than when they are pushing up.
