What is the diffrence between Dominator and Dominator GT
as1248
I'm Going to buy a new computer:
I7-860
Gigabyte GA-P55A-UD6
two of Western Digital Caviar Black WD7501AALS 750GB in Raid 0
SAPPHIRE 100284L Radeon HD 5750 1GB
Gigabyte Odin pro 800 W
Gigabyte Sumo 5115
and I want to buy ram from crosair
but I have confused when I see two types of them
Dominator and Domintor GT
So What is the diffrence between Dominator and Dominator GT??
remark: I don't intend to overclock!
redduc900
Inactive Moderator
Portland, OR
The GTs include the Airflow Fan, and are also available in speeds up to DDR3-2000MHz. Compared to the standard Dominators, which are only available in speeds up to DDR3-1866MHz. Like Richard mentioned, since you don't plan on overclocking the Dominator DDR3-1600MHz kit should do just fine.
A
as1248
ok I will take Dominator
...unless you really like the Red/black design lol.
Really it is very attractive lol :thup:
Thank you every body for yor cooperation!
your information was very helpful!
Rich'[ard]
Melb, AUS
they are pretty sexy kits :santa:
if i had the $$ and was doing a build for looks as well as performance i woudln't mind spending the extra dollars for the GT kit.
they look pretty good IMO
same reason why i took the Reaper X over the original Reaper kit (aside from the slightly better performance).
