What is the max speed u can overclock to?
Hot
I got an Iwill KA266-R and a 1.0 gig CPU. I wonder what is the top speed i can overclock it to. Anyone has the same system? And what is the top speed it can run stable at? Thank you.
It depends on how lucky you are, since not all cpu's are created equal, some can oc very well but others not.
It also depends how good cooling you are using, this is major factor in oc current Tbirds.
To get an idea you can check the cpu database on the www.overclockers.com main page.
