What is the most powerful 120mm fan for < $10.00 each?
killem2
Trying to revamp my cooling for my case. I need 120mm fan. LED is a here nor there, if it has to be there, red/blue/green is about all I really care to see.
killem2
killem2
Nice, thanks for the updates. What are your opinions on filters? And that jet engine looking coolers is awesome, but I must ask, how hard is it to clean out?
only.one.ryder
40+ db start to get loud if you go with more then one.
and for under 10$ i do think the R4 from coolmaster are some of the best DP to CFM ratio.
GREEN:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103062&cm_re=R4-_-35-103-062-_-Product
RED:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103063&cm_re=R4-_-35-103-063-_-Product
BLUE:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103060&cm_re=R4-_-35-103-060-_-Product
EDIT:
Also, iv read some other post/fourms on the r4's and they say its miss labeled. its really (IDK #'S anymore) but i wanna say its around 2300-2500 RPM and 23 DB.
I LOVE THESE, as i went from 8 Yate Loon High Speed 120mm Fan (40dBa, 88CFM) (looks at my sig and sees it needs a update) to 8 of the green R4's and it just blows the yate loons away (still love for them tho, they lasted me a good 2-3 years)
jcw122
I highly recommend you change your target price to <$6. Don't let stupid resellers dupe you with their highly inflated prices.
Hey Zeus
Heaven
I used to have 100cfm fans in an old rig and it drove me crazy. Good luck with the wife with those. :)
killem2
killem2
I was looking over the reviews of the kaze, and I knew they were loud but people are saying stuff like heard it from outside my house, sounds like a vacuum, sounds like a hair dryer.
Is this really accurate? From a case fan?
MIAHALLEN
Senior Member
YES! THose are very loud...my buddy picked up one, on his open test bench we had to raise our voices to talk...kinda like being on an airplane ;)
I have a 250CFM Delta that about the same noise...but twice as much airflow :D
Marlin P Jones has these 120 X 25 mm Delta fans for $4.95 each. They are rated at 86 cfm and 37.6 dB noise. They are pulls from new equipment from what they say in the listing.
These would be a much better choice :)
Moto7451
Senior Something
LA, CA
Thats why I mentioned a fan controller. Seriously, my Deltas have those lovely fluid bearings so at 1/2 power or less they're much quieter (and push more air) than cheapy 60-80CFM fans. The bearings make a huge difference haha. In the case of the jet engine cooler, Fans seem to always run better at 1/2-3/4 rated specs. Usually you loose all the motor noise. If you feel adventurous, get it and a fan controller.
CualvezAsteria
For a more normal speed/noise fan, I highly recommend the ZM-F3. I've seen it $7-$10 at places. It has incredible and imo the best noise/airflow ratio (I've owned GentleTyphoons, San Ace H101, Panaflo, and S-Flex). Petra's has it for $7 right now.
muddocktor
Retired
New Iberia, LA
The only problem with the ZM-F3 is finding them though. When places have them in stock they seem to sell out quickly. But like you said, it's a good fan. So if you see them in stock and want them, you better order fast.
muddocktor
Retired
New Iberia, LA
For a good sound to output ratio the Slipstream fans are really good. 110CFM @ 37 dBA.
http://jab-tech.com/home.php?cat=81&sort=price&sort_direction=0
Jab-tech seems to always have good prices on fans.
I had to edit your post, man. The dumb forum software saw where you had typed the "110CFM @ 37 dBA" without the spaces left in and made it an email address link.:sly::comp:
I've found that the Scythe Slipstream fans to have greatly inflated cfm numbers myself. And the other Scythe fans I've tested with have had numbers a lot more believable. I think that Scythe just quotes whatever numbers the actual oem of the fan gives them and doesn't actually do the measuring. In the case of the S-Flex and Gentle Typhoon series fans, they are made by another oem than the Slipstreams. I haven't found who the oem of the S-Flex is but the Gentle Typhoons are made by Japan Servo and I have looked at their specs on it, which tally with the specs that Scythe gives too.
