What is the Problem? How can I resolve?
beginneroc
Melbourne....Australia
After fresh Vista install Bootsect.Bak shows on Slave Disk (D) Format of C and D should have cleared.
How can I prevent this happening? I am unable to backup system to D:being constantly thrown to DVD/CD (F)
AVG Free shows $AVG. $RECYCLE BIN. Boot. System volume Information when I scan.
What is the problem.
Thanks in advance. :bang head
Flurp
Washington
What are you using to do fresh install? Are you formatting both hdds during the fresh install? you are not trying to save your information are you?
jmdixon85
Cumbria (UK)
Mmmm> thanks for the redirection Flurp but I'm still confused by this. Sounds like a screenshot of "disk management" would help here.
B
beginneroc
Solved!!! Thanks to all for input. I disconnected D: Overwrote C: from Parted Magic EraseDisk. C: was as if New disk. Fresh install of Vista to C: including format forcing BOOTSEC.BAK to C: and installed other stuff to C:
Used Parted Magic to create New Disk for D: by overwriting. Initialized and formatted through Disk Manager and we look like a goer. Just about to do backup shadow of C: to D: Hope it works.
Thanks to all! :beer:
B
beginneroc
All seems ok now. Hope it stays that way.
Thanks again for all efforts to help! :)
The problem seems to have been Bootsect.Bak on D: with this being viewed as boot drive and unable to format or delete through disk Management.
