The subject says it all... what should mine be set at also?
Emericana Member Joined Jan 8, 2002 Location Boulder CO Apr 9, 2002 #1 The subject says it all... what should mine be set at also?
C calypso_ri Registered Joined Jan 21, 2002 Location Rijeka, Croatia Apr 9, 2002 #2 VIO states for Voltage Input/Output... It's 3.3V mostly... At least on my board (ASUS P2B)...
JaY_III Senior of BX Joined Dec 17, 2000 Apr 10, 2002 #3 VIO standard is 3.3V Mine is 3.5V I think, Safe is under 3.7V Danger is 3.8+V What should your be set to???? Depends on your system stability... Video Card Stability, ect. If you have an unstable system, but are sure your CPU can take it, try upping your VIO and see if that helps.
