- Mar 30, 2002
- Toronto, Canada
I have had my AIW Radeon 8500dv 64Mb for about 3 months now and have had it overclocked to 285/410 from the default speed 230/380. The RAM is only 5ns so its only rated for 400mhz (ddr) but I dont think 410mhz should be that much of a stretch for it. I have added a Corb and some RAMsinks along with an 80mm 35cfm fan to the ramsinks sucking air from the bottom of the case towards the top. The card has not been Vmodded and it has had the Corb and RAMsinks for a few weeks now. Please check out the pictures here so you can see what I am talking about with the 80mm fan.
Anyway the card had been running fine until last week when it started getting Crazy artifact type things all over the screen (see the image below, Ive never seen anything like this before)...at first only while gaming, then they would pop up even while the system was sitting there idle. So I lowered the clock speeds back to default and all was OK, then I OC'd the core back to 285 and it was still OK. Then I lowered the core to default and OC'd the ram back to 410 and boom, crazy checkerboard artifacts again. So I assume it must be a problem with the RAM.
Ever since then the core has been at 285 and the ram at 380 (default) and all was well (except that I wanted my RAM OC'd too) until today when the artifacts popped up while browsing these forums (with the RAM) at default clock speeds.
It cant be temps, since I actually had the case open when it happened today (after taking those pics) and ambient temps are lower today then they have been since I got my card.
So what is wrong?? could it be that the 80mm fan is causing some vibrations which are causing errors... i have rubber washers on the fan (see the pics at the link above). I used Artic Silver epoxy not Arctic Alumina but as I said the RAM sinks have been on there for a few weeks and the problem just started recently so I dont see how it could just start causing a problem now.
Any help is welcome... I plan on removing the 80mm fan (permanently) and remounting the ramsinks more carefully (tape the RAM connectors) as soon as I find some time cause I know I got a little AS epoxy on one of the RAM connectors and I know AS epoxy can be conductive (although I have tested it with an ohm meter and found it to be non conductive). But again I dont see how it would work fine for so long then start causing a problem now.
Sorry for the long post but I wanted to cover all the bases... could it just be faulty RAM?
