What kind of mem modules are these?
The Doors
Vesuvius Senior Ocer
Athens - Greece
Please, I've got from a friend 3 mem modules, but I don't understand what kind of Dimm are these, coz doesn't fit properly in the standard Dimm slots!
Chip & layout are marked by Hyunday, and there are 3 label with written:
- HYM572A400 ATNG-60 AB
- Hyunday 9716
- IBM 32M 60ns E P/N 20H0681 FRU 19H0289
and on chips there's this code: HY5116400A T-60 9715A (or 9713A) Korea
Thanks in advance for your support ;)
Adriano.
bobt17
Michigan
are u sure its not a simm?? if it wont fit into a sdram or ddr slot then my guess is its a simm of edo ram
The Doors
The Doors
Athens - Greece
Thanks ThePunkGeek ;)
so they seems to be 3x32Mb Dimm for an IBM RS/6000 Risc, uhmm....now I understand the fitting probs :D
The Doors
The Doors
Athens - Greece
Yes, I'm sure, I've tried on different systems (Simm & Dimm) but the 'hole' in the middle of the module seems to be 1-2mm shifted laterally than the standard Dimm :confused: and onestly it's my first time :)
Don Quixote
OK, USA
I agree with bobt17, I think that they are old simm chips, Fast Ones TOO!!! 60 nano seconds!!! blazin' speed! MMMMMMMMBOY!
The Doors
The Doors
Athens - Greece
My mistake, I haven't specified very well :rolleyes:
the PCB is long as a standard Dimm, but the two 'holes', not only one like I said, are just shift of 1mm ;)
bobt17
Michigan
hey they wouldent be a rimm would they?? i havent used any rdram but do u think that could possibly be what it is? or is it out of an old comp or something?
The Doors
The Doors
Athens - Greece
Bobt17, I think that we are speaking of special kind of Dimm, supposed to work on a IBM RS/6000, and Yes, they are coming from an old Computer, but no info are available from this friend of mine ;)
The Doors
The Doors
Athens - Greece
FireMogle said:
I think the holes/grooves are for different voltages and ECC for RAM if my memory is correct.
Yes, probably you are right FireMogle ;)
Please, no one of the Guys & Gals present on the Forum are experienced in IBM Risc HardWare?
Still many thanks for your support ;)
Adriano
