What one 2700 or 3200?
Xaeron
Missouri
I'm getting ready to order a 2.6C (800mhz fsb) and I need to know what kind of memory I need. I need pc3200 right due to it being 200mhz fsb x 4 right? TIA
Yes the buffalo winbond stuff from newegg is like 85 bux very good stuff 215-217 fsb.
how bout this stuff? it's a bit cheaper
KINGSTON KVR400X64C3/512 512MB 400MHz DDR PC3200 DIMM RAM CL3
73 bucks
are you going to overclock?
IF yes then get some crosair xms pc3200
if your leaving it all stock then the kingston stuff is pretty decent stock
Specifications:
Type: DDR
Capacity:512MB
Speed: 400 MHz PC3200 more info>
N82E16820141412 $73.00
$73.00
Motherboards - Intel
ABIT IS7-E ,Intel 865PE chipset Springdale for Socket 478 P4 ATX motherboard RETAIL
Specifications:
Supported CPU:Intel® Pentium® 4 Socket 478 processors
Chipset:865PE / ICH5
FSB:800/533MHz
RAM:4x DDR Single/Dual Channel DDR 400 up to 4GB
IDE:2 x Ultra DMA 33/66/100 Up to 4 Devices
Slots:1x AGP PRO, 5x PCI Slots
Ports:2xPS2, 1xLPT,1xCOM,1xLAN, 4xUSB and Audio Ports
Onboard Audio: 6-Channel AC 97 CODEC on board
Onboard LAN: On board 10/100MB LAN
Onboard SATA: 2 channels Serial ATA 150MB/s RAID more info>
N82E16813127156 $99.00
$99.00
Processors
Intel Pentium 4 / 2.6CGHz 512k socket 478 Hyper Threading Technology 800 MHz FSB - RETAIL
Specifications:
CPU: 2.6GHz
Type: Pentium 4 Northwood
Cache: 512K
BUS: 800 Mhz
Socket: 478
3-year MFG. Warranty- more info>
think all of this will work ok together?
Your best bet would be to check your Motherboards website for recommended DDR400 modules to use since you are not going to overclock.
The 865 and 875 motherboards are quite finnicky with ram so best to use what the manufacturers recommend.
After you have found that out use pricewatch ( an example ) to find the best spot to purchase the ram and then use
resellerratings.com (also an example) to validate the quality of the online places to purchase from.....
you don't consider running the memory out of sync with the bus overclocking do you?
leaving the processor in spec and ram in spec - more tweaking that overclocking
