What Power Supply to buy?
Dagon
Southern CA
What Size power supply am I should I use if I going to use:
ABIT SA6R w/Celeron II
2 7200rpm hardrives
couple of NIC's, Assorted fans, etc..
Strictly air cooling, no peltiers or anything. Will it do fine with a 230W or should I just get a 300W? It's going to be an upgrade for a old 166 system.. I can't imagine what's the power supply in there now.
Dagon (Apr 05, 2001 02:27 a.m.):
2 7200rpm hardrives
I recommend a good PSU such as an Enermax or Sparkle in the 300W+ variety.
Terry
You say right :)
Enermax is the best Ps possible: you can choice 330, 450, 550 or 650Watt always with 2 double ball bearing fan and temperature controller.
The code for 330w is EG351P-VE, for other specs look at www.enermax.com.tw
Have a nice O/C.
The Doors (Apr 05, 2001 10:16 a.m.):
You say right :)
Have a nice O/C.
Enermax no longer manufactures the 330W PSU. They have gone to a 350W unit.
Terry
2 7200rpm hardrives
Doesn't sound like you're doing anything extreme, and dual psu's are definitely not necessary.
I ran a CD, DVD, Burner, 2 40gig 7200 HD's, 1 20 gig 7200 HD, Voodoo 5000 (with dual fans on board) vid card, Live card, Promise ATA 100 card, 2 nic cards and other minor stuff like 4 case fans on a 250 w psu w/o problems. I recently upgraded to a 300 w just for kicks but see no difference. Save your money for a different upgrade. If you're not going pelt, it's not necessary to "bring in the big guns". =)
You still say right :)
The new code is EG365P-VE, this is a 350Watt Ps, always with double fan ecc....
Have a nice O/C.
Those Enermax PS are damn fine units. But, don't forget about the Antec PS. I have a 300 watt unit and have been very pleased with it. Remember, the new power supplies are ATX style and won't work with an old style AT motherboard.
Any ole 300W PSU thats AMD approved should be more than enough for any Intel system (unless you throw in peltiers or a 4 disk raid array and a couple of optical drives). The important thing is that it is AMD approved, as it will have more current on the low voltage rail, and all the current will be a bit cleaner. I also find the voltage is a bit above spec on most AMD approved PSUs.
Thanks guys...I think I'll get a 300W. Or maybe a 400W and then swap it for the Antec 300W in my system . ;D
I used an Antec 300w power supply for a long time, but decided to 'step-up' to an enermax 330w w/ fan control. Talk about a sweet deal, it was quieter, cooler, and even lower my case temperature a half degree celcius =D. I'm super pleased with mine, I won't get anything else BUT enermax now.
aeon
Jeff Evans (Apr 05, 2001 07:44 p.m.):
Exactly.....if you're looking for a car to get you from home to work and back....you wouldn't need a caddy. A generic brand probably wouldn't last as long but would be sufficient.....no need to go overboard and drive that Lincoln Town Car just to work.
