I don't like MBM5.
it annoys me, so many things on my motherboards always can't be picked up with this program.
it just annoys me, cause theres so many things that just seem to do nothing.
I personally found a different program called "speedfan"
it picks up the RPM of all yours fans automatically.
it shows your voltages all automatically.
it shows your CPU speed, automatically.
Temps automatically...
I have MBM5 startup w/ WinXP and use it all the time.
Speedfan is also one of my favorites only because there's an indicator that tells you if the temps are on the downswing or not.
Both programs will give you almost identical temp and voltage values.
