What program should I use to monitor temps... In Ubuntu?
gwar2288
Title says it all really, finally managed to get my broadcom wireless card to work :clap: and am running Karmic as I type :comp:
Now I just need something to monitor temps with. I am not too worried, I have already done my overclocking work on Windows, but I'd like something there, just to keep an eye on it and to hit the button if **** hits the fan ;)
muddocktor
Retired
New Iberia, LA
If you don't get any response in Cooling about this over the next day or so, I'll move this over to the Alt OS forum for you. Since I don't do Linux I can't help you out on this, unfortunately.
G
gwar2288
Heh, it was a coin flip for me. On one hand it's Linux, on the other it's related to cooling :D
Bobnova
Senior Member
Install lm-sensors, and then i like Gkrellm to monitor the temps, it's a really good program.
G
gwar2288
Awesome, thank you :D
However, I cannot detect my CPU temp. It picks up my GPU and HDD sensors however :(
Ah well :shrug: Thanks again anyway :D
xrodney
Czech Republic
Did you tried to run command like "sensors-detect" ?
If i remember this should be used after installing lm-sensors to make it look for all sensors on your system.
Sorry if if i got command wrong its quite some time now i was running linux and cannot test it.
Bobnova
Senior Member
That is indeed the correct command, it needs to be run as root though.
Once lmsensors is all configured Gkrellm should pick up the cpu temp.
