As the title suggests I need to get a rad for my water-cooling build. This is my first one. I decided to go water-cooling because of the obvious reasons, temps and silence. Anyways my system specs are as following:
Case: NZXT-Phantom
GPU: HIS 6990 4GB (non oc)
CPU: Intel i7 950 (planning on oc'ing but only slightly)
PSU:Corsair AX 1200W PSU
RAM:8 GB Kingston 1336Mhz
MOBO: ASUS Rampage Xtreme III
WC stuff I've already bought:
Fans: Noiseblocker NB-Multiframe M12-P 120mmx25mm Ultra Silent PWM Fan - 1000-2000 RPM. X4
Coolant: Feser One UV blue
Rez: Swiftech MCRES-Micro ReV 2
Pump:Innovatek Eheim HPPS Plus 12V Water Pump (132.1 GPH)
Tube:Tygon R-3603 1/4" ID (3/8" OD)
CPU-Block:EK Supreme HF Universal CPU Liquid Cooling Block
GPU-Block:Koolance VID-AR699
Compression fittings x12
So what I want is to Water-cool my GPU and my CPU and my question is, What radiator do I need?
This is my first post here and anyone that answers this will be my hero! this will be my favorite PC forum of all time if you answer!
Case: NZXT-Phantom
