folding
If you use few cpu-intensive tasks for a whole week, expect about 80 points. With the latest gromacs WU, it could be as high as 330/week. But then, the PAla7-2 is not gonna last very long, though there might just be more new gromacs WU's on the way that offer similar boosts in production.
To track progress, get Electron Microscope 3-
www.em-dc.com
To run the gromacs core, make a shortcut to the f@h exe and edit the proerties. (Right-click, choose properties) On the target line, you'll see the directory the f@h exe is located in quotes. add these flags: -advmethods -forceasm
Ex: "C:/Program Files/FAH/
[email protected]" -advmethods -forceasm
There is a space before the hyphen in each flag. You will need to restart the client using this new shortcut to receive gromacs work units. If it is already folding something, it will need to finish the current unit before it switches over to gromacs.
You could then drop this shortcut in your stratup folder so that it would run at strat-up. Or there a a couple of other weays to go about this. Check on the threads about gromacs or the folding FAQ sticky if you want to explore a few other options.
