what should i use?
SharkyTM
Ithaca, NY
ok... i've got a tbird 1.2 133 AXIA, y series... it overclocks well, but i need more cooling. i wont do watercooling, and right now, i have an alpha 6035 with the delta... what should i go with? glaciator, sk-6 are what i've been considering... any suggestions?
SharkyTM
1588Mhz is not good enough for you? Going any higher could possible lower your cpu performance anyways.
Simple..If you want the best air cooling then get the following: Swiftech 462-A rev 1 heatsink, a delta 68 cfm fan, and some artic silver2 grease. I have this setup and to keep my hot *** [email protected] amd at 40c. It realy monsters over your case and looks cool and is the best secure way to install a heatsink. My only gripe is the niose from the fan, but that can be fixed with a simple rhetostat.
I recomend www.crazypc.com to buy this whole setup. They shipped very fast my last order.
Goodluck.
