- Mar 19, 2003
- In front of my computer
can anyone explain this?
I have 11x200 in the bios.... W T F?
felinusz said:This is too bizarre.
I used to have the same motherboard as you - and it was fine for me with two different Thoroughbreds, and a Palomino.
Which BIOS revision are you using? When did this start? Is FSB Spread spectrum enabled in the BIOS? (big time shot in the dark)
Has anyone else seen something similar before?
(BUMP so someone who knows why it's happening can see this)
bulk88 said:Maybe the BIOS chip is faulty. I have had MBs were the bios chips partialy failed, It didn't reload the settings but weird setting appeared all over the place.
felinusz said:Before you go through the ordeal that is usually associated with contacting ASUS (in my experience anyways), you might want to try reflashing the BIOS, and changing to revision 1005 - just to see what it does.
Also, what speed is your RAM running at?
Does GCPUID still give you that "alternative timer" window? And what happens when you set the BIOS to run at stock speed?
