OK, I have an Enlight case with seven (count 'em) fans. Two case fans (top rear blowing out, bottom front sucking in), a power supply (400W) with two fans (one blowing out of case, one sucking into PS), the HSF (blowing into HS), video card fan, and chipset fan. The MOBO is ASUS A7V133, the CPU chip is T-bird 1.33 AYHJA running at a pitaful 1 Ghz. The CPU is cooled by a Global Win WBK38 with lapped HS and arctic silver. With the case closed up the MOBO rises to 31 C and the CPU to 42 C at idle. With the case open and a house fan blowing on it the MOBO is 26 C and the CPU 39 C. Ambient is 23 C.
This seems way too HOT.
With the CPU at 1.33 Ghz and the box closed the MOBO is 31 C and the CPU 50C. Fully loaded it is 54C. Everything is stable.
I'm afraid to run at 1.33 for fear of killing this high priced CPU chip ($220).
Any suggestions????
Any suggestions????
