L
lightning
Guest
now i'm in 985 at 2.05V with ideal temp is 24C. i try to run prime95 and it start increase temp til 31C and suddenly...toop!! crash!! i was able to run 1 gigs with this chip at same voltage @ room temp below 30C. i just want to burn it in! but everytime i run prime95, it just crash!! sisoft won't crash and will stablely run at 31C!
so folks, what do u think about this problem?? is that heat problem?? will the memory hold me back?? currently using PAL6035 with sanyo denki and open side case.
