What timings do I need?
Qt_Gino
Toronto, Canada
ok I've got 1gb 2 dimms of ocz 2700 rev 3.2 ram and i can run it at stock speed of 166mhz at cas. 2 2-5-2 but i want to run it at 200mhz.... i've heard it possible if i tincker with the timings but i've got no clue as to what i have to do.... I woulkd appreciate any help u could lend me ..thx.
sandman001
Just Freeze It
just take it as far as you can testing with with memtest every 10mhz or so, if it has errors either give it more voltage, or relax the timings a bit. Then repeat, but check it every 3 mhz or so, after you first encounter errors. repeat as necessary. But, I don't advise going much over 2.8volts.
