- May 15, 2003
OK, here's the situation. Antec Smartfan 92mm i KNOW where the smartfan temp monitor is, so it can adjust the speed of the fan......is there a way to bypass it all (the temp sensor) to get the speed of the fan @ a higher rpm.... more cfm? I was thinkin of cuttin off the little knob which i think is the temp monitor.. is it? and what should i do
as you can see its in the top left of the fan center
