What water cooling sytem is best? Leufken or Swiftech?
Mr. Grinch
I want to setup a water cooling system for my dual CPU System. Which manufacturer is best compaired to quality, price and service.
Thanks,
B
Best setup:
DangerDen Cooling Cube
DangerDen Maze Block (Maze2 for SocketA)
Danner 250GPH pump
It just don't get any better.
I would have to totally agree with Jeff, I am running the exact same :)
Hey Jeff, is the maze2 block working any better for you? I thought about getting it when I bought my A-mazeing block but my MSI mobo doesn't have the four holes around the socket to mount it. If I were to use the clamp I have now the waterblock would have to be offset I guess.
I will also agree that the dangerden water cooling setup is very good. Cools excellent,no problems with it since install. Best part was getting rid of all the noisy fans, you can barely hear this system run.
NUTNDUN (Mar 09, 2001 04:41 a.m.):
I don't have the above set-up. My friend Teddy (a local overclocker) has the above setup, I just helped him set it up. His system is schweet! I've got a home-brewed water cooling rig, seriously considering upgrading to a DangerDen maze block.
I kinda thought you had a home brewed system, your mix is the one with the really green color. I would like to switch to the maze2 as said above but I don't have the four holes around the socket to mount it. I wish I had some OC'ing freaks that lived close to me.
Jeff Evans (Mar 09, 2001 03:10 a.m.):
Best setup:
Danner 250GPH pump
Where do recommend I go for that Danner Pump? What kind of pump is it?
