- Apr 6, 2001
- Norway
I thinking to cool down this:
A 1500 AMD CPU, GPU and the motherboard chipset (a Iwill KK-266-R)
I want to have a quit system.
I'm planning on buying the Cuben from DangerDen or AquaCoil from Be Cooling, what do you recommand me to buy?
Going to place the radiator on the top of my case and the pump on the bottom.
The system are going to be 3/8" tubing.
I'm planning on using a submersible pump. How much gph should the pump have? (The pump must push/suck the water furst up to the radiator, then down to the CPU, then down to the GPU, up to the cipsett, down to the resorvair and at last to the radiator)
Or what water-pump do you recomand me to use for this setup?
How large resorvair should I have?
Can I use the Eheim1048 pump for this, if yes how big must the resorvair be??
THANKS
Cuben from DangerDen =http://www.dangerden.com/product_pages/radiators.htm
AquaCoil radiatoren from Be Cooling=http://www.aquastealth.com/
THANKS
