what would you guys say about DP5-6H11 coolermaster?
fog
i think i should get something better then my stock hsf, but i dont have money to spend on fop 30$!! i saw this cool DP5-6H11, it costs only 10 on pricewach, do you know this coller? i have duron 800 stable at 995! v1.75 voltatge,
when i try to do 1001mhz, its not stable, on one giga its more stable on v1.75 then on v1.85, i gusse its because of the heat!! please tell me if i should get this cooler, i dont want to spend more then 15$
It's an ok cooler, I have it, and it makes me ablæe to run at 978MHz, that is without Artic silver.
I think u sould wait untill u have some more money, so u can get a better cooler, something like a FOP38. I'm replacing mine very soon, because I cant hit the gig with it, so I don't think it will help u very much either.
Hmm, I think that's the one me mate's got on his 1Ghz Athlon.
We swapped the fan for a 60mm YS-tech. With some Silver goop the Board thermistor reports temps of 46C under load.
Not a bad cooler for the cost- although it's a bit tight on the fitting- Took both of us, a small flatheaded screwdriver and a lot of swearing to get it fitted.
getting the volcano instead!
thanx for the posts,
i decided that i'm going after the volcano2, because its altitle bit better and costs the same!
coolme! (Apr 08, 2001 05:25 p.m.):
The Volcano has similar engineering spec's to other TT products. Don't expect too much from it.
Terry
Find a FOP 32 for about $18 to $20. It even outperforms the huge Talisol that ships with the 1333 Birds.
It sucks @$$ i have it hooked up to my t-bird and it runs 120*F IDEL and i never put a load on it so far cause i dont wanna lose mt $260 investment and im going water cooled soon
