- Oct 10, 2012
- Secret lair
IT makes sense that Archeage would cause problems, it's based on the Crysis 3 engine so I'd guess it puts a lot of load on your 6950.
Do you have good ventilation inside your case?
But Dead Island is based on the Chrome engine and -although DI isn't fantastically optimised- should not put that much hurt on the card.
What settings are used for DI?
This is for a "sing & dance" at 1920x1080 - note that shaderpath must be set by hand and then video.scr flagged as read only.
Code:
!Resolution(i,i)
!WindowOffset(i,i)
!Monitor(i) // -1 primary monitor
!BPP(i)
!FSAA(i) // Full Screen AntiAliasing, 0 - none, higher is better
!TexBPP(i)
!TextureQuality(s) // VeryLow, Low, High
!Filtering(s) // Bilinear, Trilinear, Anisotropic, AnisotropicTrilinear
!GammaFloat(f)
!MaxRefresh(i)
!Shadows(s) // Low, High
!ShadowMapSize(i)
!SpotShadowMapSize(i)
!Lightmaps()
!Fullscreen()
!VSync() // enable vertical sync
!MaterialQuality(i) // lower is better
!WaterQuality(i) // lower is better
!GrassQuality(i) // lower is better
!FXQuality(i) // higher is better
!FXFadeLevel(i) // 0-4 (lower is better)
!EnvQuality(s) // FullDynamic, RareDynamic, Static
!ShaderPath(i) // 0 - 1.1, 1 - 1.4, 2 - 2.0, 3 - 3.0, 4 - x360, 5 - 4.0, 6 - ps3
!PostProcess(s) // Simple, Normal
!DisplayDeviceType(i,f,f,f,f) //device type (LCD TV etc.): 0 - default
!Curves(s) // curves texure
Resolution(1920,1080)
Monitor(0)
BPP(24)
FSAA(2)
TexBPP(32)
TextureQuality("High")
Filtering("AnisotropicTrilinear")
Fullscreen()
Shadows("High")
ShadowMapSize(1024)
SpotShadowMapSize(1024)
Lightmaps()
GammaFloat(0.98)
MaxRefresh(60)
MaterialQuality(2)
FXQuality(3)
FXFadeLevel(1)
WaterQuality(2)
GrassQuality(0)
EnvQuality("FullDynamic")
ShaderPath(5)
VSync()
DisplayDeviceType(0,0.000000,1.000000,1.000000,1.000000)
