- Jan 3, 2012
- Ft. Myers, Fl
Hi everyone, i did my first build as a xmas present for my wife to play WOW. This is the build:
case - Cooler master elite 430, 2 120mm fans, 1 in front of case pushing air in and 1 in the back pulling air out
MB - MSI 970A-G45 am3+
CPU - AMD Phenom II x4 955 BE
Heatsink - Cooler master vortex plus, purchased this because it has a low profile and figured it would be better than stock heatsink
Thermal paste - Artic silver 5
Memory - Corsiar vengeance 8GB (2x4GB) 1600mhz
GPU - Evga Nvdia Geforce GTX 550 Ti superclocked
HDD - WD Caviar Blue 500GB, 7200rpm/16mb, SATA 6GB/sec
PSU - Cooler master extreme power plus 500w
So i have oc'ed the cpu to 3.6mhz just by changing the multipler to x18, and the voltage to 1.375, idle temps where 29-31 degrees C, i ran prime95 for a hour and maxed out at 55 degrees C but mainly stayed around 53-54.
This was a little higher than i wanted cuz i was hoping to oc to 3.8mhz but i dont want the temps to get any higher, so i figured i may need to up grade my heatsink.
Also, i wish i knew how to post snap shots of CPU-Z and Core Temp and HWMonitor to show u guys what im working with and to get any advise on what else i should be doing to oc.
Any help with a better heatsink and how to post snap shots would be great!!!
Thanks for any and all help!
