- Jan 1, 2004
- Romania, Eastern Europe
Give me some good fan & HS for a Barton 2500,I mean for a resonable price. And yes,I want to o/c it.
Thanks.
This is what I have now:
It's a SPIRE
Socket A / 370 Cooling kit
Dimensions Heat sink : 78×73×49 mm (l × w × h)
12VDC Fan : 70×70×25 mm
Bearing Two Ball bearing
Rated speed 3500 ~ 4200 RPM +/-10%
Rated power 2.4 ~ 3.60 W
Noise level 27.5 ~ 36.0 dBA
Air flow 21.70 CFM at 3,500 RPM
27.19 CFM at 4,200 RPM
Current 0.30 A
Life hours Two Ball: 70.000
Features Copper base, Temperature control & Auto restart
Application Intel : Pentium III ~ 1.4 GHz (FC-PGA2)
Pentium III ~ 1.13 GHz (FC-PGA)
Celeron ~ 1.4 GHz (FC-PGA)
AMD : Duron ~ 1.3 GHz (Morgan)
Athlon XP ~ 2700+ (Thoroughbred)
Athlon XP ~ 2100+ (Palomino)
Athlon XP ~ 3200+ (Barton)
Athlon MP ~ 2800+ (Thoroughbred)
Athlon ~ 1.4 GHz (Thunderbird)
Thermal resistance 0.45 °C/W
Thermal type T725 or Stars 420 (white grease)
Clip model 0606624
Thanks.
It's a SPIRE
Current 0.30 A
Clip model 0606624
