- Apr 30, 2004
Keep in mind, I wanna stay below $400.
*Qty* *Product* *Item #*
*Unit Price*
*Qty x Price*
*Cases (Computer Cases, ATX Form) *
*RAIDMAX Black 10-bay Case with 420W Power Supply, Model "ATX-868WBP"
-RETAIL*
Specifications:
*Case Type:* Gaming Case
*Color:* Black
*Material:* 0.7mm SECC
*Drive Bays:* 5.25" x 4/0, 3.5" x 2/4 (external/internal)
*Expansion Slots:* 7
*Front Ports:* 2 USB ports and Audio
*Power Supply:* 420W
*Cooling System:* 2 x 80mm
*Motherboard Compatibility:* ATX Form Factor 12" x 10.5" or smaller
*Dimensions:* (DxWxH) 17.2" x 7.8" x 16.9" more info>
<http://www.newegg.com/app/ViewProduct.asp?description=11-156-135>
N82E16811156135
$52.00
$52.00
*CPU Thermal Paste / Grease *
**This item is NOT REFUNDABLE, exchange for same exact item only!!**
*Arctic Silver Premium Silver Polysynthetic Silver Thermal Compound,
Model "Arctic Silver 5", 3.5-gram( 1 cc. ) tube*
Specifications:
*Thermal Conductance:* >350,000W/m2 °C (0.001 inch layer)
*Thermal Resistance:* <0.0045°C-in2/Watt (0.001 inch layer)
*Average Particle Size:* <0.49 microns <0.000020 inch
*Extended Temperature Limits:* Peak: –50°C to >180°C Long-Term: –50°C to
130°C
*Performance:* 3 to 12 degrees centigrade lower CPU full load core
temperatures than standard thermal compounds or thermal pads when
measured with a calibrated thermal diode imbedded in the CPU core
*Coverage Area:* The 3.5 gram tube contains enough compound to cover at
least 15 to 25 small CPU cores, or 6 to 10 large CPU cores, or 2 to 5
heat more info>
<http://www.newegg.com/app/ViewProduct.asp?description=35-100-007>
* (Includes FedEx Saver Shipping) N82E16835100007
$7.49
$6.9/2 pcs*
$6.75/5 pcs*
$6.5/10 pcs*
$7.49
*Fans, Heatsinks (Case, CPU, Chipset) *
*Speeze "FalconRock" CPU Cooler for Socket A/ 370, Model "5F286B" -RETAIL*
Specification:
*Compatibility:* Athlon~1.4G, Duron~1.8G, Athlon MP~2800+, Athlon
XP~3200+, Athlon XP~2700+
*Dimensions:* Fan: 80 x 80 x 25 mm; HeatSink: 80 x 80 x 44 mm
*Bearing Type:* Ball Bearing
*Nominal Speed(RPM):* 2300+/-10%
*Max Air FlowCFM):* 28
*Max Pressure:* Not Specified
*Heat Sink Material:* Aluminum/ Copper base
*Rated Voltage:* 12V DC
*Connector:* 3 Pin mainboard
*Noise(dBA):* 25 more info>
<http://www.newegg.com/app/ViewProduct.asp?description=35-150-023>
* (Includes FedEx Saver Shipping) N82E16835150023
$10.99
$9.49/2 pcs*
$8.49/4 pcs*
$7.49/6 pcs*
$10.99
*Memory (System Memory) *
*Geil Dual Channel 184 Pin 512MB(256MBx2) DDR PC-3200 - Retail
*Specification
*Manufacturer:* Geil
*Speed:* DDR400(PC3200)
*Type:* 184 Pin DDR SDRAM
*Error Checking:* Non-ECC
*Registered/Unbuffered: *Unbuffered
*Cas Latency:* 2 6-3-3
*Support Voltage:* 2.55V-2.95V
*Bandwidth:* 3.2GB/s
*Organization:* two 32M x 64 -Bit
*Special Features:* Enhanced SPD for Dual Channel DDR motherboard
*Warranty: *Lifetime more info>
<http://www.newegg.com/app/ViewProduct.asp?description=20-144-512>
N82E16820144512
$128.00
$128.00
*Motherboards - AMD *
*ABIT "NF7-S" nForce2 Chipset Motherboard for AMD Socket A CPU -RETAIL*
Specifications:
*Supported CPU:* AMD Duron/Athlon/Athlon XP Processors
*Chipset:* NVIDIA nForce2 SPP + MCP-T
*FSB:* 400/333/266MHz
*RAM:* 3x DIMM for DDR333/266 Max 3GB, 2x DIMM for DDR400 Max 2GB
*IDE:* 2x ATA 133 up to 4 Devices
*Slots:* 1x AGP 8X/4X, 5x PCI
*Ports:* 2xPS/2,2xCOM,1xLPT,SPDIF Out,6xUSB2.0(Rear 2),1xLAN,Audio Ports
*Onboard Audio:* nVIDIA SoundStorm APU(Dolby 5.1) + 6-Channel AC97 CODEC
*Onboard LAN:* 10/100Mbps Fast Ethernet
*Onboard SATA/RAID:* 2x Serial ATA, RAID 0/1
*Onboard 1394:* 2 Ports
*Form Factor:* ATX more info>
<http://www.newegg.com/app/ViewProduct.asp?description=13-127-166>
N82E16813127166
$85.99
$85.99
*Processors *
*AMD Athlon XP 2500+ "Barton", 333 FSB, 512K Cache Processor - Retail
*Specification
*Model: *AMD Athlon XP 2500+
*Core:* Barton
*Operating Frequency:* 1.83GHz
*FSB:* 333MHz
*Cache: *L1/64K+64K; L2/512K
*Voltage:* 1.65V
*Process:* 0.13Micron
*Socket:* Socket A
*Multimedia Instruction:* MMX, SSE, 3DNOW!, 3DNOW!+
*Packaging: *Retail Box (Heatsink and Fan included) more info>
<http://www.newegg.com/app/ViewProduct.asp?description=19-103-379>
N82E16819103379
$80.00
$80.00
*Subtotal »*
*$ 364.47 *
*Shipping and Handling Charge »
* Tax Instruction for All Resellers
<javascriptopupPage8('ResellerTax.htm')> How Newegg.com calculates
shipping <find_shipping.htm>**
*Grand Total »*
*$ 364.47*
**How to calculate shipping charge**
Select *Shipping Method* and * Ship to State*, then, click on *Shipping
Calculator*.
(This site requires 128-bit security.)
*Important Shipping Instructions*
* FedEx Express Saver: 3 to 4 business days plus processing time.
* FedEx 2nd Day: 2 business days plus processing time.
* FedEx Standard Overnight: one business day plus processing time
* *No delivery on Saturday or Sunday. FedEx does not ship to P.O.
Boxes.
* * No International/Canadian shipments.*
* Military APO/FPO orders welcome!* *(Due to military APO/FPO box
size, 19 inch or larger monitor will not fit. Please remove it
from your shopping cart and purchase it locally.)
* For HI, AK, and PR customers, FedEx can only ship via 2nd day or
overnight, and shipping time will not be guaranteed.
* *All orders require 24-48 hours processing time before shipping.
Newegg.com does not process orders during weekends. Newegg.com
does not guarantee same day shipping.*
* *Rush Orders*: Some orders may be shipped the same day for a $2.99
service fee. Click here for more details <warranty.asp#rush>.
*Save Cart to Wish List does not guarantee availability. All items
transferred to wish list may and will be sold out from time to time.
*Step 1 of 5*
Copyright ©2004 NEWEGG.COM Inc, All rights reserved. Privacy Policy
<http://www.newegg.com/app/privacy.asp>
*Unit Price*
*Qty x Price*
-RETAIL*
Specifications:
*Color:* Black
N82E16811156135
$52.00
$52.00
Specifications:
130°C
heat more info>
$7.49
$6.9/2 pcs*
$6.75/5 pcs*
$6.5/10 pcs*
$7.49
Specification:
$10.99
$9.49/2 pcs*
$8.49/4 pcs*
$7.49/6 pcs*
$10.99
*Specification
N82E16820144512
$128.00
$128.00
Specifications:
N82E16813127166
$85.99
$85.99
*Processors *
*Specification
*Core:* Barton
*FSB:* 333MHz
*Voltage:* 1.65V
*Socket:* Socket A
N82E16819103379
$80.00
$80.00
*Subtotal »*
*$ 364.47 *
*Grand Total »*
*$ 364.47*
Calculator*.
Boxes.
*Step 1 of 5*
