- Mar 8, 2002
- Salt Lake City, UT
I have a Thunderbird 700 Slot A .18 Micron 256k Cache
Week 21
"AMD-AO700MPR24B-A"
"210021623572"
Asus K7M No GFD, just FSB at 117.1 x 7
The HS/F is almost minus its last fan, since both are old and are dying, MBM 5 shows RPM at 2500 of the little 50mm sucker left spinning. I have an 80 mm up front pullling cool air in and a huge 200 MM 120 V AC fan in the side right over the chip pushing prob over 100 CFM no exhaust since the PSU is sitting on top of the case. It was right in the way of the CPU. The HS is a simple Aluminum "Aavid" generic brand.
My questions are..
What would be a good Slot-A(1) HS for under $30 online ( low shipping if possible ) to get it higher?
Whats a good case thats a decent size Mid - Tower with at least a 300W PSU, (considering mines only 250 and generic ) for under $50 online? - same as above about shipping
Is there any tweaks specific for this CPU that can be done with out soldering that would give noticable increase in speed while being stable. I am happy with it as is, except for the case and HS which is at this moment passing on, I see the fan speed warning flashing at me....
Well it seems I am now maintaining tolerable temps while OC'ing a passively cooled TB! Is that a record? or is it just cuz its 22 C in my basement?
Any help is greatly appreciated with this slightly older but not over the hill CPU, though the HS is RIP
Thanks all...
<edit>Just found out that 200 is only 120 mm and its a Sunon, you can check the specs at http://www.sunon.com.tw/product/ac/ac12038.htm where I found out its running around 115 CFM, very nice, no wonder I can do passive, probably should do some ducting
</edit>
Week 21
"AMD-AO700MPR24B-A"
"210021623572"
My questions are..
Thanks all...
