- Dec 27, 2008
On a customer's machine there is intermittent video signal loss. This is an old AMD setup with Phenom I 9050 CPU and 8 gb of RAM. HD 4650 pcie bus powered video card.
Screen goes black and when restarted the display reports no signal while the computer itself proceeds to boot into Windows.
If machine is turned off and allowed to sit for a time it may boot normally with a video signal but the signal is lost again within a few hours.
Today the customer banged on the side of the computer while booting when there was no video signal. This caused the video signal to be reinstated and it booted right into Windows with normal display.
Here is what I have done to correct and diagnose the problem.
1. Used different inputs and different cables, i.e, vga and HDMI and different monitors.
2. Swapped out the video card with a known good one in that same Radeon HD series. Didn't change a thing. Still got this intermittent video signal loss I have been describing.
3. Ran the Windows Memory Diagnostic which reported no issues with RAM.
4. Checked the smart drive info. No issues reported dealing with the hard disk. The disk is just few months old. You would think disk issues would
5. Stressed with Prime95 blend and for 20 minutest with no errors. So putting the machine under stress does not produce the problem.
6. Right now I am checking for Windows file system integrity with sfc /scannow. Don't expect to find anything.
My guess is this is a CPU or CPU socket problem or a motherboard problem. Maybe a damaged CPU pin or a bad trace in the PCI-e circuit somewhere.
Can't be a video card driver issue as that would not cause no signal pre windows during the boot up.
Any ideas?
Edit: no integrity violations reported by sfc /scannow
Any ideas?
