Nuclear Power Plant - N.P.P
Nuclear Power Plant
1/22/17 - Update!
This Threat started about couple months ago when I wanted to start this project. Started with buying components slowly that took couple months and ended with me posting pix of final stages.
This forum helped a lotl. This is my first ever computer build. Never built one and never helped someone to build one. All my knowledge is coming from Google, YouTube and OverClockers forum. I have watched tons of videos in the past couple months. same thing as reading and learning the numbers and concepts.
Anyway, at this very point im waiting on GPU waterblock and new tubes to ship out so then i can run the pump for a day and then boot up the system for first time.
Hello everyone.
I have a quick question for you all. I am building a custom pc and im going to heavly overclock the CPU and the GPU. both pieces are going to be watercooled (custom),
i7 6700k OC
GTX 1070 Xtreme G7 OC
32GB Gskills 3200mhz DDR4
1000W EVGA PSU with 80 Gold
Z170X G7 MotherB
SSD 1TB Samsung
Case Corsair Full Tower ATX 750D
The porpuse of this system is going to be 4k ultra settings on almost any game. going to be run on a 4k monitor.
*GPU is going to have a full neckle plate waterblock.
My questions are:
1- A 360 radiator (a fat one) with 3 high performance fans (2000rpm) is enough to cool off both overclocked CPU and GPU?
2- Can I have two radiators ( a 360mm and a 240mm ) with only 1 waterpump/reservoir? ( water presure in the loop is going to be ok? )
3- Is it safe to run the loop from pump>360rad>CPU>GPU>240>back to pump? ( the coolant is not going to be hot enough when it comes out from the CPU?)
4- My main concern is the hot coolant going from CPU directly to GPU. Is it better to send the cooland from pump>360rad>CPU>240rad>GPU>back to pump? ( the coolant presure is not going to be low in this setup?
I have done months of researches (reading, watching, pictures..) but im still confused. I know the loop is custom and everyone can do different but I am trying to understand those 4 questions plus how to get the best performance. I would rather go with ONLY 1 radiator if its going to be fine.
Apperciate it everyone. This is my first post on this website, I would like to throw the final pictures on this threat. Its going to be a black/neon green setup. I named it Nuke
Thanks again
1/22/17 - Update!
Hello everyone.
i7 6700k OC
Z170X G7 MotherB
SSD 1TB Samsung
My questions are:
Thanks again
