what's going on?
meionm
Finally after getting everthing together I started overclocking looking for limit on my cpu, I set the vcore to 1.7 and start increasing fsb, I get somewhere to 15x287, load windows, eveything looks good I check cpu on my computer and it says 9mhz, I click sisandra and run cpu test and get 65, run super pi 1000+ for 1m
meionm
meionm
It's not my vcore, dual prime stable at 283 with 1.7vcore, same vcore at 287
veryhumid
New Hampshire
I'd drop that Vcore too. If you want to max out voltage set at 1.650. If you were water cooling it might be safe. At 1.7 a lot of northwoods don't last very long. My 2.8 didn't die but It degraded my overclock.
meionm
meionm
The temps are below 15c
I copied the screen check it out
meionm
meionm
And here is one shot how it is at 283, same setup similar temps,
Cowboy X
Folding in Barbados
below 15C ?? using what cooling . If you don't have peltier or phase change cooling , then those temps are quite wrong . Unless of course you live in the Arctic and use you computer outside .
