whats the best 120mm Fan for a radiator
Mord-Sith
I need a 120mm for my radiator. I dont care about noise I just want the best one. I know there is a difference between the cfm out put and the pressure.
Panaflos are the best from everything I've heard. They come in 3 versions: L1a, M1a, H1a, Light Medium and Heavy (or so I presume) - L is quiet but effective, H is like an overclocked fan - it puts out noise like a pain though. L1s and H1s are sold at Caseetc - www.caseetc.com I think - and they have vital stats too. Hope I helped,
Stolid
BlakeN (Jun 18, 2001 12:58 a.m.):
Check out www.sunon.com for specs on their fans. I used a 120mmx38mm on my radiator. I wired in a rheo to control speed. Noise isn't bad unless it's full throttle.
