Rob Cork (Feb 07, 2001 01:29 a.m.):
Abit KT7a-RAID - the KT7's a great board, and the KT133a version is basically the same but with native UDMA100 support, and a true 133MHz fsb. If you can't find the KT7a-RAID the Asus A7V-133 would also be great - similar features, though I don't think it allows multiplier changes to be made in bios.
tfcw (Feb 07, 2001 04:15 a.m.):
A7V133 does allow multiplier changes in the Bios. No problem there but my CPU is running VERY hot on this mobo. I didn't have this problem with my MSI K7TPro2-A and the same processor.
Oh yeah..the ASUS is stable (although the MSI was also a VERY stable mobo...but I wanted to try the new Via KT133A chipset)
DaveB (Feb 07, 2001 01:23 p.m.):
MSI boards are the most stable. Asus and Abit are overclockable, but tempermental. You'll be constantly tweaking them and updating the BIOS to keep them running right. Go with MSI if you're like me and appreciate stability, i.e., absolutely no crashes or BSODs.
Eriksson (Feb 07, 2001 07:26 a.m.):
How high can you pump the fsb on the Asus A7V-133?
When is your system crashing cuz of OS or App or vid card or sound...etc. And when is it the fault of the motherboard?
DaveB (Feb 08, 2001 09:41 a.m.):
The only popular reviewer who really tests for stability is Anand. He runs intensive 24-hour benches, most sites just boot them up, play around for a while to see how far they'll O/C, and go "WooHoo". The MSI KT7 Pro 2A was the only socket A board to have zero crashes in his test. And overdoze claims he values stability over MHz.Just one more thing, regarding the question:
The answer is, it's pretty much always the fault of the motherboard. The most basic requirement for any motherboard is that it be able to run any O/S and be compatible with any peripheral. I'm always amused when guys blame their BSODs and other problems on the O/S. If something crashes on your system, but thousands of others run it with no problems, it ain't the O/S. The primary factor in the stability of any system is the motherboard.
