PROJECT LOG What's the best case
Turner.kenny5
Hello there I need help. I'm going to do an extreme overkill build and I need help on what case I need. As right now I'm going to be buying intel 7700k, 2 gtx 1080 or 1080 ti (or something better). I also need help on what Ram to get I was thinking about getting CORSAIR Dominator
Welcome to the forums Mr. Turner. As far as cases go there are many deciding factors that need to be determined before choosing a case. So you're looking to SLI 2x 1080 or 1080ti's so you will most likely need a full ATX motherboard. It looks like you plan on doing a custom water loop based on your other posts so I would recommend a full tower or large cube type case for maximum water cooling capabilities.
If you could list a full parts list of what you plan to use it will help with this process. Also have a look at the link in my sig. There's a short list of quality cases there. That list is no where near complete but can offer a good starting point.
