Whats the best way to Use Prime95?
Kunaak
Juneau Alaska
best way to Burn in the CPU?
what I have been doing is upping the Vcore to 1.85, leave it at defualt speed and just let it go for days like this.
it seems to work, but does anyone know a better way to burn in a CPU? ;)
Gravity Man
Edina, MN
I usually set the vcore to 1.85 and overclock as much as possible while still being able to run the torture test for 24 hours.
viper_wc
Canada
I'd set to the lowest multiplier setting and increase to the highest FSB setting at 1.85V this usually helps so that you can lower the voltage for higher multiplier settings(with lower fsb). Then run prime95 or loop q3 bench
