Lord Moreira
Banned till 9/16/03
- Jul 29, 2002
- U.S
mbentley said:i don't see any benchmarking differences between the whql cert. drivers and the uncert. ones. it just seems like they are just approved so you don't have to hit the little windows warning that your computer may have a meltdown if you install non-whql cert. drivers on your computer![]()
RangerJoe said:40.71's have some of the best performance out there, havnt tested the WQHL certified 40.72's yet, but the 41.30's (think thats right) seem to work just great
can be found at www.guru3d.com
SlowBurn said:
If you mean the 41.03s I have some gripes about them atm. I mean the picture quality has drastically improved, but for some reason I can't run my Geforce Ti4600 at 330/700 anymore. 3DMark won't even start the bench. Anyone else have this problem?
mbentley said:
i had the exact same problem. i would click the start button and nothing would happen. i turned it back to the default clock speeds and it was fine... must be something with the leaked drivers...
SlowBurn said:
Did you go back down to the new 40.72s and is it fine now? I haven't tried it yet, been too busy with RL stuff.
