Whats the prob
²JPortv2²
La.
Every time i log on and my DT shows, i get a message that says system32 has encountered an error an needs to close. Then it goes on to ask if i want to send an error report.
Why is this happening, and wat to do 2 fix it ?
Yakbak
Ottawa, Canada
What processes or services do you have enabled? Perhaps you could trace it down to the program loading on boot that is causing the issue, then disable it.
²JPortv2²
²JPortv2²
La.
What process do you think could be causing this problem.
