whats the right way to uninstall drivers ?
Cheesy Peas
Rotherham,UK
in control panel( windows ) add remove programs and there should be ATI display drivers, and ATI control panel, just uninstall display drivers.
PreservedSwine
Ft. Myers, Fl.
DDR-PIII said:
im getting rid of the 3.4's for the 3.2 how can do it right ?
Excelent question- I hated it when XP would automatically re-install drivers.
If you want to do it right, follow this guide, it will not only eliminate XP from popping in a new set of drivers, but will completely uninstall old drivers......
You will need to sign up to view this post, but it's free, and well worth it..
http://www.driverheaven.net/showthread.php?s=&threadid=8053
Cheesy Peas
Rotherham,UK
how about not having to sign up to something i prob wont use again, save them some space.
Just copy and paste what it says so everyone can read it.
PreservedSwine
Ft. Myers, Fl.
I wouold, but it actually includes plenty of screenshots. It's the most user-freindly uninstallation guide I've ever seen, and is WELL WORTH joining up, if but ONLY for this one post- go ahead and join, and I think you'll understand why a copy&paste just won't cut it.
Just take a peek, and then you can tell everyone else if it's worth it or not;)
FYI: I have NO affiliation w/ that site, and have never posted there, found this guide just like I'm showing it to you....
