- Feb 10, 2002
- Norman, OK
I hit 152 rock stable in prime95 for more than 3 hrs, i know its not much but my multiplier is still locked, pls post your achivements and specs to give me a better idea.
Thx
Thx
I think that rising the vcore won't help you, may be one of your pci cards is holding you back. Try it without the sound card or whatever you have on the pci and see if you can boot. Also will help you if you get newer drivers for your hardwareEuclid][CID][ said:Hey,
Any time I crank my FSB above 140 I get an error that says my config file is corrupted and that I can repair it from the recovery console. It isn't really corrupted because when I lower it back to below 140 it boots fine.
I'm running Windows XP Professional. Is this part of it? Any suggestions would be very helpful.
Thanks.
Euclid
I said that rising the vcore won't help him because his vcore is already 1.85v and thats more than enough for 150 fsbmustangman said:I disagree that raising vcore won't help, it might but not guarenteed. I had the same troubles getting over 150. When I volt modded the board and went to 1.92 I could go over 150 without the errors! It's worth a shot.
I run win2k.
