Whats your Memory Bandwidth with Sandra 2005?
xTrEmEoVrClOcKr
member
San Diego, CA
Score: 5936
What type of Memory you have: Kingmax "Hardcore" PC4000
Mhz: 256Mhz
Timings: 2.5, 3, 3, 5
I wanted to see where I stand, Post what your highest benchmark is! Make sure to post a screenshot.
7707/7631
275/5-3-3-2.5/1t (benchmark settings)
7695/7608
275/5-3-4-2.5/1T (24/7 settings)
System in sig
what should I use for my trc and dram idle timer?
as of now
trc=12
dram idle timer=16
btw i have ch-5 @ 250 10-2-3-2 1T 1:1
thanks!
Just do like I did...and try a few settings and run si sandra and see which gives the best results...some memory likes lower idle timer...some like higher...trc I would go as low as possible...
mtb856 said:
Fugger's made it up to a 370FSB on his 3.4E, but's that's on a double or triple cascade setup........... He had to run a ratio, but his bandwidth was still insane :D
You mind posting a screenie with his bandwidth...I went through almost all of Fuggers post and did not see anything about 370...did see the 350 screenie...but that was MT pics...not bandwidth pics...
Oh, it was his Memtest pic that I was mentioning..... I was just mentioning it in comparison with my own Memtest bandwidth.
From what I've heard over there, he's not able to make it into Windows at 7.2 gigs due to an issue with his SATA drives...... I can't wait until he figures it out though :D
I was wondering about that because 90 - 95% of the intel MB's cant handle more then 7.5Ghz of memory
I will say...those where impressive timings in MT...but impressive timings in MT cant yield you anything if you cant get into windows ;)...
His 5G run was at 323 FSB/HT...and even then all he did was run Super Pi...so that was probably more of a suicide or 5 minute run...too bad he coudl of gotten some good benchmarks at that Ghz...
Man...just think of the cash he had to spend to hit 5.8Ghz...and if you notice...his super pi was actually lower then his 4.8Ghz...
