- Mar 7, 2008
I finally upgraded my home network so that the two major nodes are both on 2.5Gbe unmanaged switches. Both PCs have 2.5Gbe NICs, and cabling is either cat5e or cat6 without double checking. Note I ran things more than once to check, presenting a single result for each case to keep things simple.
Crabaletta - unmanaged switch - unmanaged switch - Garuda
I downloaded and ran iperf3 as server on Garuda. Testing is carried out from Crabaletta.
Before that, a quick observation in case it might or might not be related. The 2nd switch was only 1Gbe and its replacement 2.5Gbe model arrived today. I took the chance to do before and after tests. Seeing as there was an ipv4/ipv6 option, I tried both. What I saw surprised me:
ipv6
[ 5] 0.00-10.00 sec 1.09 GBytes 939 Mbits/sec sender
[ 5] 0.00-10.02 sec 1.09 GBytes 936 Mbits/sec receiver
ipv4
[ 5] 0.00-10.01 sec 1.11 GBytes 953 Mbits/sec sender
[ 5] 0.00-10.03 sec 1.11 GBytes 949 Mbits/sec receiver
ipv4 was about 1.5% faster than ipv6. Maybe this could be due to the extra overhead of the bigger address space, if nothing else has changed? Also, I am assuming this is measuring payload at whatever layer IP sits on, which is different than the raw media rate which also has to handle packet metadata.
Never mind that, onto the new switch. I simply unplugged everything from the old one, and plugged in the new one. Simples. The whole link between these two systems should be 2.5Gbe all the way though now.
ipv6
[ 5] 0.00-10.01 sec 2.73 GBytes 2.34 Gbits/sec sender
[ 5] 0.00-10.02 sec 2.73 GBytes 2.34 Gbits/sec receiver
ipv4
[ 5] 0.00-10.01 sec 2.03 GBytes 1.74 Gbits/sec sender
[ 5] 0.00-10.02 sec 2.03 GBytes 1.74 Gbits/sec receiver
Erm, what now? The ipv4 rates are obviously a lot lower than expected. What other options do I have to tinker with?
ipv4 - reverse (Garuda > Crabaletta)
[ 5] 0.00-10.01 sec 2.76 GBytes 2.37 Gbits/sec sender
[ 5] 0.00-10.01 sec 2.76 GBytes 2.37 Gbits/sec receiver
So it is directional? Could Windows QoS be interfering? I turned it off on Crabaletta and...
ipv4 - QoS disabled on Crabaletta (also no change if I disable on Garuda)
[ 5] 0.00-10.01 sec 2.05 GBytes 1.76 Gbits/sec sender
[ 5] 0.00-10.02 sec 2.05 GBytes 1.76 Gbits/sec receiver
ipv4 - -P 2 (two connections) QoS still disabled on Crabaletta
[ 5] 0.00-10.01 sec 1.02 GBytes 873 Mbits/sec sender
[ 5] 0.00-10.03 sec 1.02 GBytes 870 Mbits/sec receiver
[ 7] 0.00-10.01 sec 1.01 GBytes 870 Mbits/sec sender
[ 7] 0.00-10.03 sec 1.01 GBytes 867 Mbits/sec receiver
[SUM] 0.00-10.01 sec 2.03 GBytes 1.74 Gbits/sec sender
[SUM] 0.00-10.03 sec 2.03 GBytes 1.74 Gbits/sec receiver
No change. That's where I'm at. Any thoughts?
ipv6
ipv4
ipv6
ipv4
