Johnny Knoxville
Disabled
- May 29, 2002
When will i be able to dual two p4's? i heard it's coming soon
the only Xeon chipset that has an AGP interface is the intel860 which uses the overly expensive RDRAM memory
but the boards cost 400 bucks or more
64026402 said:The rumors of a dual P4 non Xeon board have never paned out.
There is not enough power in a P4 to make it worth while anyway.
Intel does have a good processor that actually does a decent amount of work per clock cycle. Itanium 2. But is a little pricey and isn't x86 compatible except in emulation.
Xeons are the best bet if your stuck with Intel right now.
SP said:
Next week that will change as there will be at least one new Xeon chipset that will also support AGP. That will be E7505, aka Placer, and it will support AGP 8X, dual Channel DDR, and PCI-X. Boards based on this chipset will also support the new 533MHz FSB Socket 604 Xeons as well as the existing 400Mhz FSB socket 603 Xeons. Of course this will likely not be any cheaper than I860/Rdram and may in fact be more expensive as dual channel DDR motherboards will be more complex to manufacture than Dual channel Rdram boards. Anyway, all the major motherboard manufacturers are expected to have boards based on this new chipset really soon.
Almost but not quite. The cheapest Xeon board is the Supermicro P4DCE+, which can be found for under $350 shipped on pricewatch. This is, of course, an existing I860/Rdram board as the Placer boards don't launch until Nov. 18th. Don't think that the P4DCE+ must somehow be a lower quality board because it's cheap. It's a very fine board. It's the same board as the P4DC6/P4DC6+ with the exception that the onboard SCSI controller is missing from the board. So, if you don't need SCSI or if you prefer to use your own SCSI PCI card then the P4DCE+ is a great low cost choice.
By the way, Prestonia Xeons (the Xeon equivalent of Northwood) already support Hyperthreading and have done so since their launch.
AMD-a-holic by chance?64026402 said:The rumors of a dual P4 non Xeon board have never paned out.
Civic_Addict said:Don't count on it.
XEONs are essentialy P4s with different sockets.
AMD-a-holic by chance?![]()
I understand getting good deals. I'm a cheap *** myself when it comes to some things. Things aside from my 'toys' that is. Car, computer, R/C..... Those don't get cheap things put in 'em.64026402 said:
I have poor loyalty. I go with the bang for the buck or the latest good deal. I have a P4 at 2.8, good deal from a freind. Plus my dual P3 and my 1.1 Celeron notebook. Right now the best power per dollar is the dual AMD. So the wind blows this way today.
