- Jan 17, 2001
What grits should I use?
And what buffing compound do i need?
MidnightClocker (May 14, 2001 12:49 a.m.):
Shadow ÒÓ (May 14, 2001 12:57 a.m.):
Some recommend a final sand with Artic Silver as a lube on the final sand, but I believe that's about as much overkill as my polishing this thing to the mirror finish.
Colin (May 14, 2001 01:16 a.m.):
Some recommend a final sand with Arctic Silver as a lube on the final sand, but I believe that's about as much overkill as my polishing this thing to the mirror finish.
And lapping and water cooling aren't overkill?
Seriously, the Arctic Silver trick works. Instead of leaving residue from your paper and lapped object in the surface imperfections, you get some Arctic Silver there in the mix. That's where you want a thermal compound.
will everyone please try a little (couple drops) of dish soap it really keeps the finer papers from clogging so quickly the surfacants in the soap will carry away the particalsColin (May 14, 2001 01:18 a.m.):
Wet, and flush the paper frequently. If you wet the back of the paper, it will stick to a flat piece of glass.
