Where to buy Lian-Li 60/61/65 cheapest?
Calavera
Pasadena, CA
directron.com, newegg.com, xoxide.com are a few I've found.
Where did you buy your Lian-Li case from?
I'm looking for a Lian-Li 60/61/65 in black.
Thanx.
EDIT: So far, coolerguys.com seems to be the cheapest. They have the 65 black for less than $100.
Thanx for the info.
But the cheapest is still coolerguys.com. The Lian-Li 65B sells for $100 with $14 shipping. pc-beyond.com sells for about $20 more. =)
i've recommended pc-beyond before, but after reading their reseller ratings, i will never recommend them again. Although my transactions with them have gone smoothly (pc-65 case) there's some real horror stories on there.
Also, most likely these cases aren't USB2.0 (the ports in the front) I got mine from pc-beyond and it's USB1.1
mpcparts.com is not that bad either... they're a little more expensive but I've had only good experiences with them.... their lian li side panel (with clear window) is only $25, about the cheapest I've seen... :)
