Where to find 120mm Air Ducts?
dja2k
Texas
I have 2 120mm fans intakes that I want to extend using 120mm air ducts, but I can't seem to find any for sale though. I am looking into air ducts like the ones that come with cases on the side panel. I don't have any hard drive cages and that space is wasted so I thought of extending the front fans with the air ducts. Anyone seen any of these on sale somewhere? Thanks
dja2k
Look for 4 inch diameter drier vents in lowes / home depot / your local hardware store.
Though from what you describe, the benefits from using that ducting would be minimal at best.
Like this?
Probably need some modding to screw/secure it to a fan...
Thanks! I had found those already but they don't have any mounting holes to connect them to the 120mm fans. Thought maybe I can find those with pre-cut holes already. All side panel ducts of cases seem to be 80mm to 92mm and maybe they have never made 120mm ones. They have been very hard to find.
dja2k
