M
mark
Guest
Hello all, I have a slot 1 p3 700e (retail/cbo) OCed to 1085mhz at 1.75v with an 86w peliter and alpha p3125s running at -9°c idle and less than 10°c under EXTREME* full load for 48 hours. I have potted the peltier and siliconed perfectly, but I am wondering if I can put a higher wattage peltier on. Maybe a 117w baby or something. My questions are; Will that alpha be able to remove all that heat? I have a 2nd 300w power supply didicated only to the peltier, will it run a 117w peltier? Also where can I pick up a higher wattage peltier?
(*[email protected], Prime 95, Sandra, 3d Mark 2000, and playing mp3's at same time)
Well thanks for any info.
check my baby out; http://www.mjstebbins.com/case.htm
